17-08-2013 #1
The more I play about with my CNC, the more I find I need a lathe to mill round or square solid bar for small projects.
My question is, when you buy a mini lathe such as the "Metal Worker Super C3 Mini-Lathe " or simular, do you get everything you need to ; as an example = milling down a 40mmx100mm round solid bar of mild steel to 35mmx100mm, then cutting a round pocket in the center at one end ?
Or are there hundreds of pounds to be spent for bigger jaws and different cutters etc before you can start to do such things ?
I have never owned one, so I do not have any exp with this.Last edited by dudz; 17-08-2013 at 05:50 PM.
Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne
SOLD: Various small CNC machines - ISEL/Unimatic
By badgerman in forum Items For SaleReplies: 14Last Post: 22-01-2020, 09:58 PM -
RFQ: Small sized Parts need making, small batches
By Ptee in forum Projects, Jobs & RequestsReplies: 3Last Post: 17-01-2014, 06:07 PM -
eBay: large amount of machines on e bay lathes mill plus other stuff
By Dellboy in forum Items On eBay UKReplies: 0Last Post: 17-06-2012, 09:35 AM -
WANTED: Wanted: Small Metal Work Milling Machine
By 07trb in forum Items WantedReplies: 0Last Post: 04-03-2011, 06:58 PM -
Lathes
By Web Goblin in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 18-02-2011, 10:32 AM
