    You taking the Pi** M8
    Nothing wrong with that question.??
    DudZ for inside turning you need a Boring bar and for general outside or face turning then you just need standard tooling which comes in few forms.
    Have a look on this page and you'll see sets cheap enough to get you going,Lathe Tools - Arc Euro Trade
    When you get more into it you'll probably buy a few of the indexable tools. Look for indexable tooling and you'll see different forms and cutting angle's etc.
  2. The Following 2 Users Say Thank You to JAZZCNC For This Useful Post:
  3. #2
    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 06-06-2026 Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    Great... Will do thx.
    Just suming up wether it is more practicle to pay someone else to do the turning or set myself up. So gathering all the info I can.
    Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
    Can't answer that question but what I can tell you is that the lathe is the Most useful tool in my shop and I wouldn't be without one. . . .It's also SOOOO therapeutic and rewarding.!!!
  5. #4
    Nice one jazz, had a change of heart & went to the same spot as you.Lathe Tools - Arc Euro Trade
  6. #5
    One thing worth mentioning about the indexable tooling is not to get one of those sets with lots of different tools for a seemingly good price. Apparently they'll be poor quality, so you're much better off buying just the ones you need individually. To start with you're probably much better off using HSS tool steel and grinding your own since it's really easy to do and saves a lot of money. It's only when you start cutting hard materials, or bigger quantities that you'll get fed up of regrinding the tool and want a carbide one.
  7. The Following User Says Thank You to Jonathan For This Useful Post:
  8. #6
    In addition to this, particularly if buying from eBay, make yourself familiar with what's in the the "machine tool sets". Some sellers start off with these but sell the contents individually to make more profit.
  9. The Following User Says Thank You to birchy For This Useful Post:
  1. SOLD: Various small CNC machines - ISEL/Unimatic
    By badgerman in forum Items For Sale
    Last Post: 22-01-2020, 09:58 PM
  2. RFQ: Small sized Parts need making, small batches
    By Ptee in forum Projects, Jobs & Requests
    Last Post: 17-01-2014, 06:07 PM
  3. eBay: large amount of machines on e bay lathes mill plus other stuff
    By Dellboy in forum Items On eBay UK
    Last Post: 17-06-2012, 09:35 AM
  4. WANTED: Wanted: Small Metal Work Milling Machine
    By 07trb in forum Items Wanted
    Last Post: 04-03-2011, 06:58 PM
  5. Lathes
    By Web Goblin in forum Milling Machines, Builds & Conversions
    Last Post: 18-02-2011, 10:32 AM
