Thread: Boxford TUD conversion Mach USB
17-08-2013 #1
This is my first post for my conversion of a late model Boxford TUD lathe I bought from the Bay over 2 years ago .. I bought this model lathe has I didn't require power feeds or gearbox for my conversion ..
When I first bought the Tud mach3 was primarily parallel port , which I could see being outdated soon so was opting for usb connection over parallel.
USB boards were rare running Mach 2 years ago , I now have a AKZ 3 axis usb board which after dry setting up with NPN proximity sensors , speed sensor ,stepper drivers etc seems great , I have even deliberately ran the board at the side of my plasma cutter to see if it miss steps badly but none noticed ( returned pointer to original dead vertical after several movements back and forth to zero) .. Good for a plasma table then ???...
Heres the spec..
USB mach motion board 3 axis
x Axis Nema 23 stepper ball screw C5
z Axis Nema 34 stepper ballscrew C5 double nut
6/8 position tool turret ( see dumpstercnc - YouTube ) great ideas...
1 1/2 hp 3 phase vfd with board connection and control via Mach
full coolant control ( high/low pressure)
Remote panel with touch screen dual MPG encoder start stop pause fro etc
THE LATHE
I bought the lathe local ish , Glossop way from a coal merchant who used it for king pin bushes , It had previously been modified to run a Z Axis leadscrew with gear drive.. changed to 240 badly but was absolutely brilliant on all the ways ;solid no wear , even the standard X axis leadscrew had only a little backlash.
The lathe came with a load of bits and bobs , 2 really nice chucks way to big for the lathe great condition. At 8 and 10 inch they were a little big sold via the bay along with 2 nice 5 and 6 " pratts
the lathe has a 5 inch height being the later type not the old 41/2 ..
The headstock is well built running 17 roller bearings ( full spec here Boxford Lathes)
Yesterday I removed some of the pieces I will not be needing ...Zaxis leadscrew ,apron plates ,changewheels ,chuck guard ,toolpost these will be sold later to further fund this project ..
I will add photos of the lathe in the next post along with some advice on setting up the board and motors..
21-06-2016 #2
Hi did you ever move forward with this build
Boxford vmc260 to mach3 conversion
By jamesgates1000 in forum Boxford Vertical MillsReplies: 22Last Post: 30-01-2020, 11:47 PM -
CONVERSION: boxford vmc 300 mach3 conversion
By bigred5765 in forum Conversion Build LogsReplies: 14Last Post: 05-07-2018, 06:05 PM -
Dyna mechtronics DM3000 lathe , mach conversion
By dazza in forum Lathes, Lathe Rebuilding & ConversionsReplies: 31Last Post: 12-12-2015, 04:35 AM -
WANTED: Looking for a MKII Boxford duet for conversion to Mach 3
By BlueBot in forum Items WantedReplies: 0Last Post: 20-05-2014, 06:07 PM -
Problem with Mach 3 converted lathe x axis Boxford TCL 160
By FarrerDesign in forum Boxford LathesReplies: 5Last Post: 07-08-2013, 09:37 PM
