So after spending 2 years with a non ballnut (entry level) CNC machine , I've just ponied up for a proper used CNC machine with ballscrews & decent drivers (btw - woaah ...what a difference!)
Now I can't immediately lay my hands on my dial indicator, so just wondered...is there normally much in the way of measure-able backlash when ballscrews & ballnuts are deployed? (bear in mind this is a used machine ...albeit the machine doesn't look heavily used).
For those of you that have CNC machines with ballnuts ....is your backlash compensation setting in your CNC app set to zero?!Last edited by HankMcSpank; 13-09-2013 at 10:16 PM.
14-09-2013 #2
How many times over the years have said do your self favor and buy some proper drives. . .Lol
If you can see it without dial indicator then they are knackerd.!! . . . If you have backlash then it can often be seen on cut edges, esp with circles has a step where the cut starts & finishes.
Yep set it to Zero and don't bother with it.!!. . Using Backlash comp pretty much defeats the point of having ballscrews and really it's very poor substitute for good screws often used by the acme screws mill users start with. . . . Personally Wouldn't even bother with it and just put real screws on.!
RFQ: Ballnut Mounts needed.
By dudz in forum Projects, Jobs & RequestsReplies: 1Last Post: 05-03-2014, 09:01 AM -
WANTED: Ballnut Bracket needed please
By EddyCurrent in forum Items WantedReplies: 3Last Post: 24-02-2014, 11:15 AM -
RFQ: help needed to make cnc machine maybe 2-3 and will pay
By scnc in forum Projects, Jobs & RequestsReplies: 10Last Post: 22-11-2012, 12:31 AM -
Need help setting up a CNC router machine please
By 1albobs in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 27-02-2012, 06:16 PM -
Help with setting up my cnc and engraving machine's
By soyeb in forum General DiscussionReplies: 2Last Post: 30-05-2011, 11:51 AM
