    Oh before I forget your not from Yorkshire are you.? My best mate at school was called Paul Green but he moved away.!
    Strangely I am!
    But Whitby in North Yorkshire. I've never moved, so we must be different people. (I will update me profile)
    Regarding the belts, that's exactly what i meant. Cheers.
    Which would you recommend?
    Single long belt, or two shorter ones as per your picture.
    Or is it 6 of one & half dozen of the other?
    Greeny
    Last edited by Greeny; 18-08-2013 at 09:59 PM. Reason: pressed post instead of preview. Doh!
    Quote Originally Posted by Greeny View Post
    Strangely I am!
    Ah was just up road few a weeks ago at friends in RHB.
    Well seen has I went with the long version I'd have to say that but really there's nothing in it and I only went with long because it was easier to make covers (Which never got made) . . .Oh there's a tip for you DONT EVEN THINK ABOUT turning machine on until you have finished all you planned to do, you'll never do another thing to it again for least 5yrs if you don't.!!
    Ah was just up road few a weeks ago at friends in RHB.!
    A gem of the NE coast. Was in Dolphin for a pint or two just last week!
    Thanks for the info on belts, and the warning about finishing before firing up. That definitely applies to me!
    I have been thinking about the advice given so far and am now thinking about toning in down a bit.
    Here is a new draft, with quite a smaller footprint, that is simpler, and should be a lot easier to build. As well as cheaper for Rails/Screws etc. which i still have to buy.
    Have added M20 ball feet so i can adjust the lean angle.
    Greeny
ID:	9581Click image for larger version.
  1. BUILD LOG: Steel frame cnc router design/build
  2. BUILD LOG: Monster fixed gantry router for aluminium & wood
    By jonboycnc in forum DIY Router Build Logs
    Last Post: 12-01-2014, 11:26 PM
  3. BUILD LOG: Steel/Aluminium design/build, sorta smallish, cuts ali hopefully
    By mart154 in forum DIY Router Build Logs
    Last Post: 19-09-2013, 05:48 PM
  4. BUILD LOG: New build - fixed gantry mill using extruded profile
  5. BUILD LOG: Fixed Gantry Router
    By lateAtNight in forum DIY Router Build Logs
    Last Post: 28-05-2009, 11:30 PM
