    Denford MIRAC CNC lathe.
    Specification: Swing over Bed: 250mm (10”)
    Maximum Turning Diameter: 160mm (6.25”)
    Maximum turned length: 180mm (7”)
    Spindle Bore: 21mm (0.8125”) No. 3 M.T.
    Spindle Nose Type: A2 42mm (1.625”)
    Spindle Speeds: 0 – 5000 R.P.M.
    Feedrates: 0 – 1200mm/Minute
    Spindle Motor: 1 H.P.
    X axis travel: 85mm (3.375”)
    Y axis travel: 200mm (8”)
    Coolant capacity: 18 Litres
    Machine resolution: 0.01mm (0.0004”)
    Machine Weight: 320 Kg. (705Lbs.)
    Electrical requirements: 240 Volt SINGLE PHASE
    Machine Length: 1090mm (43”)
    Machine Depth: 970mm (38.2”)
    Machine Height: 625mm (24.6”)
    Machine Features:
    RS232 Port. Plug for external keyboard. Auxilliary 7 Pin socket.
    (Serial Port, Parallel Port) Coolant pump, sump and drain valve.
    Internal lighting above work area. Safety interlocked sliding door with window.
    Internal and external jaws for 3 Jaw chuck. Chuck key.
    4 brand new and 1 used quick release tool holders. Release key and tool clamp key.
    Parting off tool with indexable carbide bit and holder.
    Built in enhanced colour graphics display and membrane keyboard.
    Floppy Disc Drive.
    Emergency stop button.
    Control Software has over 40 features to allow complete control and federate over-ride of 0 –150% Other features include:
    Manual Data Input facility.
    Internal and External screw cutting.
    Tool nose radius compensation.
    Metric or imperial Prgramming.
    Circular and Linear Interpolation.
    Canned Turning Cycles.Tool Offsets for 16 Tools
    Dry Run facility.
    Toolpaths Graphics in colour 2D or 3D display.
    Program merging facility.
    Jog mode with variable feedrates.
    LAN communication if required.
    Axis over-travel limits.
    And many more (Contact me for full list)
    Software and Complete Documentation:
    MillCam Designer software. Post Processor Libraries
    Denford Industrial Text Editor software. Denford Dongle
    MIRAC Maintenance manual MIRAC operating software and backup disc.
    Denford Lathe CAM Designer instruction Manual
    Denford Mill CAM Designer 2 instruction Manual
    Denford Industrial Text Editor Instruction Manual
    Denford MIRAC offline programming instruction Manual which includes G Code and M Code descriptions and comprehensive screen displays descriptions.
    MIRAC CNC Lathe Installation, Operation and maintenance manual.
    Original Denford Technical Brochure.
    I can lift the machine onto your transport. It will fit in a large estate car.
    OFFERS INVITED.
    e-mail: [email protected].
    Phone: 01483 284114 (Work) and 01483 282627 (Home)
Name:	Lathe three quarter small image.jpg
ID:	9249   Click image for larger version.
Name:	Lathe door open small image.jpg
ID:	9250   Click image for larger version.
Name:	Tool holders small image.jpg
ID:	9252   Click image for larger version.
Name:	Jaws, keys and valve small image.jpg
ID:	9253   Click image for larger version.
Name:	Floppy discs small image.jpg
ID:	9254   Click image for larger version.
Name:	Denford Mill CAM Designer Manual small image.jpg
ID:	9255   Click image for larger version.
Name:	Communication cable small image.jpg
ID:	9257   Click image for larger version.
Name:	Control panel and display small image.jpg
ID:	9258   Click image for larger version.
Name:	MIRAC installation and Operation Manual.jpg
ID:	9263   Click image for larger version.
Name:	Lathe CAM Designer small image.jpg
Name:	MIRAC Maintenance manual.jpg
ID:	9264   Click image for larger version.
Name:	MIRAC offline editor manual.jpg
ID:	9265   Click image for larger version.
Name:	Parting off tool tool holder and tool .jpg
ID:	9266   Click image for larger version.
Name:	Side panel small image.jpg
ID:	9267   Click image for larger version.
Name:	Text editor manual small image.jpg
  2. I will be keeping my eyes on this, but I have a feeling it will be out of my price range.
    "If first you don't succeed, redefine success"
    I'll give you £100 if you include shipping
  4. Nemo1966: I will raise you to £500 CASH, and I will collect it.
    Nick Butler: But to be fair I think you should really just list it on eBay, and put the link here.
    £600 and Mad Professor Will collect it
    asto's Avatar
    Lives in Attica, Greece. Last Activity: 1 Week Ago Has a total post count of 68. Received thanks 1 times, giving thanks to others 0 times.
    Quote Originally Posted by Nemo1966 View Post
    If the machine is running properly I can pay you a thousand pounds.
    But...I do not know, is it still available?
    regards
    asto's Avatar
    Hey Nick...your e-mail address <[email protected].> returns a message which says this email address is not valid.
  8. remove the fullstop at the end of his e-mail address and it works fine.
    asto's Avatar
    Is that so?
    Thanks Mad Professor.
    regards
    asto's Avatar
    Hey Mad Professor. Do you know if this machine is still available?
    cheers
  1. Big single phase servos and drivers
    Last Post: 04-09-2013, 01:18 AM
  2. convert 3 phase to single phase?
    By D-man in forum General Electronics
    Last Post: 06-04-2013, 12:16 AM
  3. Panasonic 3 phase driver running on 1 phase?
    By gavztheouch in forum Motor Drivers & Controllers
    Last Post: 10-05-2012, 11:21 PM
  4. FOR SALE: Denford Mirac CNC Lathe with Auto Tool Changer For Sale
    By CHudson in forum Items For Sale
    Last Post: 19-02-2011, 12:11 AM
  5. Denford Mirac Electronics Refurbishment
    By CHudson in forum Computer Software
    Last Post: 17-06-2010, 08:30 PM
