Thread: Several mild steel parts
20-08-2013 #1
I need someone to turn me several mild steel parts.
Most of them are more like spacers. One part is slightly more complicated. All from 35mm dia round steel bar.
Please send me a private mail if interested.
I am in France.Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne
21-08-2013 #2
Ok Sorted now, thanks..
22-08-2013 #3
22-08-2013 #4Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne
24-08-2013 #5
25-08-2013 #6
Looks to this layman like a fine result in double-quick time Ian.
I would imagine that dudz will be well thrilled with this progress!
26-08-2013 #7
Very Impressed with the quality and time it took (or did'nt take) to make these bits. I shall put more work your way Ian.
ThanksSwedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne
Milling mild steel
By dudz in forum Machine DiscussionReplies: 33Last Post: 16-02-2014, 02:31 PM -
How do I get this widget made (a small rectangular bit of 1.6mm mild steel)
By HankMcSpank in forum Marketplace DiscussionReplies: 25Last Post: 03-05-2013, 09:31 AM -
Cutting 1.6mm mild steel with a CNC machine?
By HankMcSpank in forum Machine DiscussionReplies: 4Last Post: 01-05-2012, 09:56 PM -
Homemade desktop CNC - cutting 0.8mm mild steel out the question?
By HankMcSpank in forum General DiscussionReplies: 7Last Post: 16-04-2010, 09:37 AM -
Where to get 1/8" sheet mild steel laser/water jet cut?
By HankMcSpank in forum Marketplace DiscussionReplies: 28Last Post: 10-02-2010, 01:28 AM
