    Hi dear friends, do u thing its good ide to use ballscrews RM2505-L=2600mm on both sides of my y-axis. Could it be too long and cause vibrations ? Or should i use R and G instead?
    Quote Originally Posted by masinecc View Post
    Welcome to the forum. It would be better if you started a new thread with this.
    You could use rotating ball nuts so that the screws remained static. ..Clive
    Thanks for ur reply, would u like to post a picture from that rotating ball nut? Just to see how does it look like. Thanks !
  5. #4
    If you do a search on the forum you'll see that Jonathan uses them and so does Silyavski, they have pictures in their threads...
    Neil...
    Build log...here
  6. #5
    Great thread! plenty of useful information!
    Clayt
  7. #6
    Quote Originally Posted by Skipsoaring View Post
    Clayt
    Great thread indeed!
    I was wondering if there is a way to print this thread in its entirety? It is so long to read on the PC that I would like to print and highlight key info. Or maybe it can be saved as a file and imported into MS Word? Or maybe one of you has distilled it down to the basics already? I am open to ideas on this.
    Randy
  8. #7
    Wal's Avatar
    Just looking at this quickly - go to the top of this page - you'll see 'Thread Tools' which has a 'Printable' option that you can select. From the printable version you can print to a .pdf. You'll still need to do this for every page, though...
  1. BUILD LOG: Steel frame cnc router design/build
  2. BUILD LOG: First steel diy CNC router build
  3. Replies: 41
    Last Post: 08-02-2014, 11:37 PM
  4. A Sturdy Steel Framed Machine Design
    By Boyan Silyavski in forum Machine Frames & Beds
    Last Post: 06-11-2013, 05:58 PM
  5. BUILD LOG: 7' X 4' Steel frame build
