Hi Silyavski,
Thank you very much for putting your sketchup files up for everyone. I am in the process of designing a new machine and learning sketchup so your files will be a big help! :)
What sort of rough price does the laser cutting cost?
Looking forward to seeing your machine come to life!
07-11-2013 #2
I dont understand something
The cncrouter will have legs down to ground or the cnc on the left of your scetchup will be put on the white table
08-11-2013 #3
Hi there,
The table on the right is if sb wants to upscale it to 1000x1500 or similar,with small adjustments, using the gantry from the left. On the left is the complete machine 400x1000 which i am building now.
Furthermore have in mind the gantry can be simplified removing the raise sides if intended mainly for aluminum.
01-12-2013 #4
I ordered them in my country/ Bulgaria/ and they cost there 250 euro. + 50 for a guy to bring them when he is coming back from there in 2 weeks.
Here in Spain, the price would have been outrageous.
Anyways, its a lot of metal. I don't have the means here, that's why i preferred laser cut. But in fact if you can cut and drill and have spare time, they are quite simple to produce at home.
Now i am designing my next build and definitely will try to lower the number of parts.
09-12-2013 #5
Let me ask something
I am planning my cnc 1500X1000 and i am very close to these plans
Is it better to weld everything together or make seperately the base and then the cnc machine that will "sit" on the table. I am asking because if i weld evertything together my construction will be very heavy ( difficult moved even by 3 or 4 people )
What is better
Solution 1
one unique construction ( both table and cnc together ) or
Solution 2
two seperate constructions( the cnc and the table). Will this second solution have stiffnees issues ?
Thanks for your time
10-12-2013 #6
I personally chose solution 1, welded together. I prefer playing with additional fixtures, instead raising, lowering the bed.
Other people here on the forum however choose solution 2 . There will not be stiffness issues.
At the end is up to you. Now i am building another 1250x2500 and i also have the same doubts as it will weight considerably. Its worth noting that if not welded together, possibly you will have to use some more beams and at the end it will weight even more. For my 1250x2500 i am contemplating making a hybrid, half of the bed welded, half removable.
10-12-2013 #7
It is possible i didnt make my self clear beacause of my english
Syliavski i will use your photo to explain
When i say cnc i mean the element A of your picture
and when i say table i mean the element B of your picture and not the cutting table
So the question is
Will i have any stiffness issues if make two different construction A and B and then let A rest on B
Or i must make one construction both A and B together in order to have more stiffness.
The problem is that if i make one unique construction it will be too heavy
10-12-2013 #8
10-12-2013 #9
the element A is a benchtop cnc 400x1000x200. The element B is not a table. It is another CNC, 1000x1500x200. It is the same, just scale the gantry.
So A is strong enough even if you put it on a simple table/strong enough/ . There will be no compromise of stiffness. Same with B.
In other words just follow B design if you like it. It would weight 130kg if following the design. Look at this thread also: http://www.mycncuk.com/forums/router...ddy-cnc-2.html to see it in real life
10-12-2013 #10
Silyavski i know that element b is not only a table.
I just use it as an example of table in order to give you understand what i mean
So you tell me that if i make a benchtop cnc 1000X1500 and bolt it on a table ( whatever strong table that can handle such weight ) i wont have any problems right?
There are currently 15 users browsing this thread. (0 members and 15 guests)
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM -
A Sturdy Steel Framed Machine Design
By Boyan Silyavski in forum Machine Frames & BedsReplies: 0Last Post: 06-11-2013, 05:58 PM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM
