Well, that's an obvious way to set up the epoxy on the gantry. You know, the kind of "obvious" that's only obvious when someone else says it!
I've been kicking ideas around in my head for the last week or two about how to align the Y rails for "constant spacing" if I put them on the top and bottom of the gantry bars for my new design. Easy enough to lay the gantry on its back and use epoxy to level the Y rails on the front face, but I couldn't work out how to do it where the fixing faces for the rails were not in the same plane. Easy enough if you have an accurate level surface to put the gantry on and do one rail at the time but how do you generate that initial level surface in a home workshop? So use one of the level surfaces you created when you used epoxy to set up the X rails! As I say, it's obvious once someone else has pointed it out...
In practice, any idea of how much out of true a typical length of, say, 50x50 or 80x80 steel tube would be? Are we talking about a mm or two, or significantly less than that? How much does the epoxy thickness vary, in other words?Last edited by Neale; 28-01-2014 at 10:26 AM.
28-01-2014 #2
This should help http://www.parkersteel.co.uk/media/p.../JPSBS0010.pdf I was looking for it yesterday when I wanted to look at how "true" my beam might have been. Don't forget you're also at the mercy of the stockholder and transport to keep the steel flat and not to induce any additional bending/torsion etc...
The Following User Says Thank You to njhussey For This Useful Post:
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM -
A Sturdy Steel Framed Machine Design
By Boyan Silyavski in forum Machine Frames & BedsReplies: 0Last Post: 06-11-2013, 05:58 PM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM
