24-08-2013 #11
you are quite right. However let me explain please. 10cm more of rail on both sides+10cm more of screw+10cm more of steel profile=no more than 60 euro, which is irrelevant in this build. If we look into KG , they are 5-6 kg more on the gantry
However an ATC is very expensive. And is quite necessary for 3D jobs. Should the need arise to upgrade, for the mere cost of 2 more short supported rails and bearings+another chinese spindle i can mount double Z axis with minor modifications and most importantly without compromising the work dimensions. One spindle will rough the other will detail and finish.
I mean, there also some other points of the design that are done with some things in mind. Its not a general hobby machine.
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM -
A Sturdy Steel Framed Machine Design
By Boyan Silyavski in forum Machine Frames & BedsReplies: 0Last Post: 06-11-2013, 05:58 PM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM
