    Couple of things.!! . . .The Z axis is wrong and your weakening not making stronger.? The spindle hanging down like that in conjunction with rail/bearing setup is a constant length lever at any Z extension.
    It won't allow any better clearance when cutting has the Tool length mostly dictates this and your spindle support plate will still catch just like the bottom of Z axis would.
    Much better option IMO would be to flip the rail and bearing setup so you have a variable length lever when extended giving much better strength and just build a sturdy spindle bracket that allows percentage of the spindle body to extend below Z axis plate.
    This extension along with tool length will be give enough clearance for most 3D work. If the guy needs more clearance then better to buy longer tool and cut slower than compromise the machine in all other areas.!!
    With the proximity sensors (Or limit switches) because of the small gaps required to work correctly then I wouldn't put them at the ends were they will get run into if crashed. Position them so they get passed by or over this way nothing gets crushed.
    Thanks guys for the input. I seem to have been missing the obvious.
    I redesigned it following the advice. Now things seem better / to me at least :-) / . What about the result? By the way i have bought already the spindle brackets/2/ . I liked the design because can fix them on a guiding plate so if i have to move them its easy to align them.
    So now the rails move and the bearing blocks stay at optimal position. If he wants to cut thin material he can fix a 10cm high MDB surfaced table made from a couple of boards glued together so there will be no need to change spindle position at all. And take it off when he likes to do deep jobs.
    Can i cut the motor shaft from the back side? Is it enough place for the cables of the motor? See picture. I need to further redesign it a bit otherwise i have to solder it with the motor in place , he he he. Ok, i wouldnt do it so. Just joking.
Name:	spindle mount.JPG
ID:	9770Click image for larger version.
Name:	z axis cnc 140x80 profile.jpg
ID:	9771Click image for larger version.
Name:	z axis  2 cnc 140x80 profile.jpg
ID:	9772Click image for larger version.
Name:	z axis 3 cnc 140x80 profile.jpg
ID:	9773Click image for larger version.
Name:	z axis 4 cnc 140x80 profile.jpg
  1. BUILD LOG: Steel frame cnc router design/build
  2. BUILD LOG: First steel diy CNC router build
  3. Replies: 41
    Last Post: 08-02-2014, 11:37 PM
  4. A Sturdy Steel Framed Machine Design
    By Boyan Silyavski in forum Machine Frames & Beds
    Last Post: 06-11-2013, 05:58 PM
  5. BUILD LOG: 7' X 4' Steel frame build
