26-08-2013 #11
Thanks Dean,
I finished with a 130mm wide fron z plate. It should be enough. I dont believe it can compromise anything, as in my router i have exactly this plate using only one slide with the wide flat rail+ 2 bearing blocks and is ok strong. However i would not like do it like this in this build, cause later i have to play a lot with hole placements and finding screws that could fit under the plate and then aligning it. As i did with mine.
I have another question. When laser cutting, should i do exact holes that hold the plates to the bearing blocks or i should elongate them. Cause how do i know that the rotating nut will fit exactly at that place. Otherwise i will loose some millimeters from the travel. How it is done?
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM -
A Sturdy Steel Framed Machine Design
By Boyan Silyavski in forum Machine Frames & BedsReplies: 0Last Post: 06-11-2013, 05:58 PM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM
