14-10-2013 #11
I need some help here with the Leadshine AM882 drivers and the SY60STH86-3008BF motors from Zappautomation.
-As far as i understand the auto finding of the parameters using the dip switch would be enough?
-However i wonder what step/micro-stepping should i use with the 1605/z/ and the 1610/x,y/ ballscrews? having in mind the way i build the machine.
-Also about the Switch 8 at the drive.
the manual says:
Pulse signal: In single pulse (pulse/direction) mode, this input represents pulse
signal, each rising or falling edge active (DIP switch configurable); 4-5V when
PUL-HIGH, 0-0.5V when PUL-LOW
So i asume rising is Pul High and falling edge is Pul Low. I wonder which one will work with my C23 board from CNC4PCLast edited by Boyan Silyavski; 14-10-2013 at 10:14 PM.
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM -
A Sturdy Steel Framed Machine Design
By Boyan Silyavski in forum Machine Frames & BedsReplies: 0Last Post: 06-11-2013, 05:58 PM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM
