14-07-2014 #111
On the photos maybe so, but in real life they look normal. Furthermore the actual distance where they are not attached to something is very very short, so they are reinforced by the ball screw nut and the gantry.
Now i want to say it:
The machine is ready and running
Thanks to all who helped
and all who watched the progress.
I would like to write soon a more detailed final conclusions, as these days again learned many things.
But for now i would say that i am extremely happy with the result.
Now about the final accuracy i achieved. Today i run it for first time cutting. My typical starting test is 25mm OD circle in 50mm square
Pictures speak better than words but lets say that all the careful fiddling payed itself and the final/accumulated/ accuracy of the machine without any compensation on mach 3 motor tuning and so is
0.01-0.02mm
or less , having in mind that the digital caliper measuring may be not perfect. As you can see perfect super clean circle cut. No mismatch or whatsoever.
PS.The bed is 5cm thick so the Z at the test was extended at its lowest point.
All motors are tuned at 8m/min but i believe it can do much much more. I will test it further when on the floor, cause its quite dangerous now to move very fast, the supports flex like crazy.
After 1h of continuing run/ i am surfacing the 10mm plastic bed i fitted over 50mm wood and composite board/ the motor temperature at Y and A/the gantry motors/ is 55C and the X and Z motors is 35C . Its 24C outside.
Soon will post video and some further notes .
Thanks again!Last edited by Boyan Silyavski; 14-07-2014 at 05:57 PM.
The Following User Says Thank You to Boyan Silyavski For This Useful Post:
14-07-2014 #112
Well done. :)
14-07-2014 #113
Hi Boyan,
Just seen your Pm. Sorry not been watching your thread so much as I tend to not to drop in much on those who are experienced or getting along good.
Well you certainly have progressed buddy and done an absolutely cracking job my friend. Looks excellent withTank like strength.
. . . . Health and safety will like that colour scheme certainly won't miss it . . Lol
Look forward to seeing video..!! . . . . . WELL DONE.
14-07-2014 #114
Excellent. Really nice build. Well done..!
Wal.
15-07-2014 #115
Excellant Machine buddy, a real credit to you.
I am very jealous.
keep us posted with all the things you make on it!.
15-07-2014 #116
Cracking build thread, really solid well built machine and an inspiration...
15-07-2014 #117
Hi Buddy
Excellent build and well worth the time and patience you put into its construction.
Mike
15-07-2014 #118
11-08-2014 #119
Just installed it at its new home. The precision continues to surprise me. Instead of accumulating, all small imprecision neutralized each other, may be pure luck but still under 0.01 -0.03mm, it seems i can not measure it properly without introducing error. No need though, i am happy.
Surfacing aluminum resulted in glass like surface, small marks are not seen by naked eye and scratch test with fingernail leave impression of trying to scratch glass.
The C23 Bob works like a charm. But the integrated spindle control is erratic. I supply it with 12v stable voltage and it plays the output to spindle with 0.2v witch translates +-200rpm, which makes the spindle sound annoying. Will contact the maker. As i see it i will change the small pot with a big one external, in the hope to cure this problem. All PSUs i use are overrated at least by 100% and brand ones, so may be its the pot.
Next machine - no Flimsy: 8 wire alarm cables, connectors to box, 1 component paint.
The 0.8kw spindle seems now/ as i knew from the beginning/ way underrated. This baby deserves 3kw one and will be called - The Reaper :-). I am boasting :-)
But for its purpose is ideal.
Here is a video of it working. Unfortunately i forgot to make video when it was slicing aluminum and took it when we were testing some 3D jobs. I am surprised from RhinoCam, quite capable and i was able to figure in a minute how to program the 3d job.
A little noisy video, but i wanted to be heard what sound it makes. If i dont forget in a week or 2 will be making some aluminum parts there, so will make another one.
11-08-2014 #120
I have no words
Excellent job
And one more time i want to say that Deans help , your ideas (about frame),Jonathans calculator, and Eddys suggestions drive me along this long trip that called cnc building. Thanks again.
One question
Are you using servos or steppers?
VagelisThe creative adult, is the child who survived
There are currently 15 users browsing this thread. (0 members and 15 guests)
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM -
A Sturdy Steel Framed Machine Design
By Boyan Silyavski in forum Machine Frames & BedsReplies: 0Last Post: 06-11-2013, 05:58 PM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM
