20-09-2014 #32
All pulleys and belts are from beltingonline.com
Nothing special, ball screws machined normally. 2 grub screws on pulley. A drop of instant glue on the shaft. If I was doing it for myself i would file or drill the shaft where the grub screws are. Now it's more forgiving for mistakes
On the big machine I am building now for myself I use only aluminum pulleys as it would be geared 20:30 t and the rotating nut is heavy so I don't want to have too high inertia. These I bought from China as here prices are prohibitive. Aliexpress.
Normally you don't need any special machining given that the motor plate is not thicker than 10mm.
On the Z however is good idea not to make it too strong especially if geared for some reason. Cause hitting the bed can do some damage especially with strong motor.
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM -
A Sturdy Steel Framed Machine Design
By Boyan Silyavski in forum Machine Frames & BedsReplies: 0Last Post: 06-11-2013, 05:58 PM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM
