08-02-2015 #34
The machine when long rails epoxy is poured must be glued to the floor so you will not bump it later. Then long rails mounted. Then first i poured epoxy on the gantry top , the gantry in normal position as near as it would be in final setup. Then flipped the gantry 180 degrees and the leveled top epoxy now down resting on the already leveled long Y rails. Then i poured epoxy on the low gantry rail and on the legs. So now we had everuthing parallel, gantry legs, low rail and upper rail.
Then i squared the gantry top rail as described bellow. In short i squared a straight edge on the long rails. Then using 2 equal sized aluminum bars and checking them square against the straight edge i squared the top rail. Then additionally using only one piece at both sides i carefully finished the job feeling the scratching . Drilled and mounted the same way. See first picture
Now i had 1 top rail ready and square.
The bottom gantry rail.
I mounted the plates on both rails. The plates that screw to the bearing blocks. The Z was still only pieces, not soldered. Then via 2 clamps i mounted the lower rail more or less. But clamps not tightened very much. Then using the front Z plate that will be later soldered to the both plates that screw to the bearing blocks i checked and aligned perpendicularity to the squared straight edge resting on the long rails , picture below.
Note should be taken here that when i bolted the 2 plates from the Z i pushed them from behind till they touched the screws, so i know they are alligned to the bearing blockes, as the holes are laser cut. I mean because of this i am sure that their edges are parallel with the corresponding rails. Later i will have some additional opportunity to align them on one plane/the z face plate/ as i can move one of them a bit back
So i mounted the lower rail. Z was carefully spot weld fixed while all was bolted on its place. No paint anywhere on the machine where bearing blocks contact with frame, metal only.
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM -
A Sturdy Steel Framed Machine Design
By Boyan Silyavski in forum Machine Frames & BedsReplies: 0Last Post: 06-11-2013, 05:58 PM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM
