08-02-2015 #141
The key there is to leave possibility for alignment.
I mounted the plates so all bolts touched the holes from one side, and as they were laser drilled they were more or less straight. But later i drilled the holes 1-1.5mm wider. So at the moment of mounting i had not only the margin of the hole itself , but of the widened hole. So its easy to adjust cause there is space that allows it.
The other key is to have 2 precision squares and 1 straight edge. So at all times you can check and assure perfect fit. You can not measure how perfect, but if you insist and try that no visible gap is left at any place, you will finish with very precise machine. And not be lazy, cause you need sometimes to check a simple thing 10 times untill you are definitely sure its straight.
And when i say check, i mean check with strong led torchLast edited by Boyan Silyavski; 08-02-2015 at 04:53 PM.
The Following User Says Thank You to Boyan Silyavski For This Useful Post:
20-03-2015 #142
Silyavski, do you think 10mm steel is minimum for Z axis?
I hink that I will at least try to build my Z axis from steel. If I dont succeed that I will go for aluminium :)
20-03-2015 #143
Steel is cheaper, faster and easier if you don't have a mill or other cnc. 10mm steel and that having in mind the way i did it, where the rails and the rectangular bars that the rails lay on, play the role of ribs that strengthen all. You will be surprised how flexible is 10mm of steel if not strengthened by bracing plates that provide strength in contrary direction.
I managed to mill with that Z/180mm fully extended/an aluminum plate- 1.5mm deep pass, and lack of cooling and proper bed fixture was the problem to go deeper per pass.
13-04-2015 #144
Hi dear friends, do u thing its good ide to use ballscrews RM2505-L=2600mm on both sides of my y-axis. Could it be too long and cause vibrations ? Or should i use R and G instead?
13-04-2015 #145
13-04-2015 #146
Thanks for ur reply, would u like to post a picture from that rotating ball nut? Just to see how does it look like. Thanks !
13-04-2015 #147
28-05-2015 #148
Great thread! plenty of useful information!
Clayt
30-12-2015 #149
Great thread indeed!
I was wondering if there is a way to print this thread in its entirety? It is so long to read on the PC that I would like to print and highlight key info. Or maybe it can be saved as a file and imported into MS Word? Or maybe one of you has distilled it down to the basics already? I am open to ideas on this.
Randy
06-01-2016 #150
Just looking at this quickly - go to the top of this page - you'll see 'Thread Tools' which has a 'Printable' option that you can select. From the printable version you can print to a .pdf. You'll still need to do this for every page, though...
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM -
A Sturdy Steel Framed Machine Design
By Boyan Silyavski in forum Machine Frames & BedsReplies: 0Last Post: 06-11-2013, 05:58 PM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM
