02-04-2017 #11
Dont get stuck too much into literature. real life is different.
Real world examples:
On this video you will see this machine https://www.cnc-step.de/fraesmaschinen/ engraving stone. And my machine is on another different level of speed, strength and precision from the machine that is demonstrating this.
Another video plus more info on bits . Again as you see the machine is not something special.
I already bought 3 diamond bits yesterday, from the expensive ones, PCD 70 degree with 0.4 point or something. So very soon will be able to demonstrate you.
About the hardness. The diamond is actually chipping the material, cutting it. Its not like pushing it. And you know diamond is much harder than granite.
Even on a flimsy machine you can engrave using spring loaded tool like this .
But to hard engrave and V cut granite obviously your machine design has to be rigid of course. My machine was designed to accept an oscillating air hammer head, a little stone cutting will not be a problem.
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM -
A Sturdy Steel Framed Machine Design
By Boyan Silyavski in forum Machine Frames & BedsReplies: 0Last Post: 06-11-2013, 05:58 PM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM
