22-08-2013 #4
OK so motor 1 controls the number of turns of wire on the bobbin? How will you determine when and how to stop winding?
If I read right, motor two moves the feed point back and forth? If not synced to the bobbin rotation you're going for random fill rather than side-by-side winding . Are you sure thats what you want? I assume therefore you never fill the bobbin completely. (never done guitar pickups but many years back built a coil winder for amateur radio equipment, transformers, etc. so principle is similar)
I guess the wire feed spool is lightly braked to maintain tension in the (fine gauge?) wire.
Fixing linear rail - DIY practice
By CharlesJenkinson in forum Rails, Guideways & BearingsReplies: 1Last Post: 10-02-2014, 12:53 PM -
Open Rail, open source linear rail?
By Musht in forum Open Source Designs & PlansReplies: 0Last Post: 15-06-2012, 12:21 PM -
WANTED: Where can I get some 8 - 10mm linear bearings - rail
By alanb in forum Items WantedReplies: 4Last Post: 21-07-2010, 07:10 PM -
FOR SALE: Linear rail and bearing
By black5f in forum Items For SaleReplies: 5Last Post: 02-07-2010, 07:23 PM -
Supported linear rail question.
By IN-WondeR in forum Rails, Guideways & BearingsReplies: 20Last Post: 05-02-2010, 12:25 PM
