    A quick question. Can anyone clarify the wiring between the Optoport V3 breakout board and the DQ860MA stepper drive.
    I ask because the breakout board has DIR, STEP, GND & ENA while the drive has ENBL-, ENBL+, DIR-, DIR+, PLS- & PLS+.
    Jim
  2. Is breakout board open-collector outputs? do you have manual or online link.
    General arrangement would be one of:
    BOB output connects to + input of drive through suitable resistor, all - inputs connect to BOB GND (active high outputs)
    or
    BOB output connects to - input of drive through suitable resistor, all + inputs connect to voltage source on BOB (open collector outputs)
    See attached file, well if this worked.
    Hi Jim, Just take the negs (-) to any Gnd's on the Opto V3 you won't need any Resistors the drives will work fine.
    Dean.
    Lives in Marple Stockport, United Kingdom. Last Activity: 19 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote I ask because the breakout board has DIR, STEP, GND & ENA while the drive has ENBL-, ENBL+, DIR-, DIR+, PLS- & PLS+.
    In this case STEP = PLS if that helps further. ..Clive
  6. Quote Originally Posted by JAZZCNC View Post
    Dean.
    I'll bow to your better experience on this BOB Dean, the manual is useless on what type of outputs they are.
    Thanks for all your advise.
    Many more to come. Lol
    Jim
  8. OT, many many moons ago I used to have an identical colour Clubman 1275GT, bored out 1340cc, blueprinted, 731 cam and twin downdraft webers with a small bonnet scoop. Was fun on and off the track!
    Sorry Irving wasn't meaning you were wrong just rushed reply and should have Said I've used several of these BOBs so know won't need Resistors on these drives. .
    Irving, this is a fully lightened and balanced 1380 with 286 scatter cam and all the frills. Was my pride and joy as it handled fantastic, but it had to go.
  1. WANTED: parker CD20 stepper drive
    By drumsticksplinter in forum Items Wanted
    Last Post: 29-03-2014, 03:35 PM
  2. Wanted: Parker CD20 Stepper Drive
    By drumsticksplinter in forum Classified Ads, Buy, Sell & Swap
    Last Post: 29-03-2014, 03:33 PM
  3. What voltage for stepper drive?
    Last Post: 22-01-2014, 10:49 PM
  4. Stepper motor drive using mach3 from parallel port
    By hmarwat370 in forum General Electronics
    Last Post: 04-02-2013, 08:55 AM
  5. Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
    By LoveLearn in forum Gantry/Router Machines & Building
    Last Post: 08-02-2012, 01:52 AM
