28-08-2013 #5
The work envelope is pretty small, so I can't see doing any heavy lifting :)
Front diagonals should be designed just so a "full size" 600mm wide sheet fits in between them.
Basically, the heaviest "full size" I can see myself working on, would be maybe a 25mm-ish aluminium plate. 800x600mm of that weighs in just over 32kg, so wouldn't be much of a problem to wiggle in even if the front diagonals would be in the way...
Design Help Pt2 Required for CNC design/Build
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 38Last Post: 21-07-2014, 02:05 PM -
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM -
BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
By Greeny in forum DIY Router Build LogsReplies: 8Last Post: 19-08-2013, 08:26 PM -
