16-09-2013 #10
Oh forgot to spot this but was more looking at the frame than the gantry.! . . . . Mentioned this before many times .!! Wouldn't have the Y axis like that with a rear piece so basicly creating a box with no sides. It's just adding weight and costing money it gives very little strength. Get your self a card box and cut sides out and see what it does.?? . . .Same principle.
It also adds other complications in the build because if the edges are not machined perfectly 90deg it skews the box making it parallelogram which will cause bearings to bind and stick when bolted together.Last edited by JAZZCNC; 16-09-2013 at 10:35 PM.
Design Help Pt2 Required for CNC design/Build
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 38Last Post: 21-07-2014, 02:05 PM -
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM -
BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
By Greeny in forum DIY Router Build LogsReplies: 8Last Post: 19-08-2013, 08:26 PM -
