17-09-2013 #19
Apart from it looks like there's not enough room for the ballnut.? . . . Have you accounted for it.?
Yes I'd have the top wide because you can and it will help and have the bottom most you can spare.
Well if they are within reach then stretch to them because they are in another league to round rail. 15mm will easily handle the loads but the bearings are not always ideal due to there smaller size but they will easily do the job.
Design Help Pt2 Required for CNC design/Build
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 38Last Post: 21-07-2014, 02:05 PM -
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM -
BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
By Greeny in forum DIY Router Build LogsReplies: 8Last Post: 19-08-2013, 08:26 PM -
