Thread: Proximity Switches
21-10-2013 #16
The four you have are Normally Open type, the preferred type for limit switches is Normally Closed.
Also take note when you mount them, if you notice they use brass, stainless, polypropylene mounts.
The last two may be normally closed, it does not say, some of these just change a voltage level so that the input decides if it's on or off.
This manual shows the wiring arrangements but obviously for their own board.
http://cnc4pc.com/Tech_Docs/C31R1_USER_MANUAL_REV1.pdf
You could wire the sensors so they operate the coil of a N/C relay then use the relay contacts as inputs to your breakout board but it's a backward as you have introduced more things to go wrong.
Personally I would replace them all for 3 wire N/C type.Last edited by EddyCurrent; 21-10-2013 at 02:53 PM.
Proximity limit switch problems
By davrich in forum General ElectronicsReplies: 16Last Post: 12-03-2018, 01:58 PM -
Proximity switch NPN or PNP
By Matt81 in forum General ElectronicsReplies: 9Last Post: 19-04-2014, 11:38 AM -
Proximity Wiring Problem
By Bruce in forum General ElectronicsReplies: 7Last Post: 13-01-2014, 07:21 PM -
Proximity sensor help required
By plasticsales in forum General ElectronicsReplies: 12Last Post: 21-08-2013, 07:02 PM -
Proximity Sensors as Limit Switches ?
By Lee Roberts in forum General ElectronicsReplies: 5Last Post: 03-10-2009, 07:04 PM
