So I've got a small CNC machine (30 x 20), it's got a water cooled spindle (which I've not used yet)...but frankly the thought of tubes running back to a large bucket, which will no doubt get contaminated seems excessive (bearing in mind my CNC machine is located in - what was meant to be - our dining room!
So I seek a compact & silent (ok, perhaps silent is stretching it ....let's say very low noise) solution ....something that's a closed loop (so I don't have to worry about contamination). So I;m browsingebay (as you do) & found this....
New Silent 23DB Water Cooling Circulation Pump For Spindle Motor CNC Router | eBay
...ok, yep, a Chinese seller & as usual, this isn't so much an advert, more of a teaser for you to try & piece together th puzzle. So to my question....would this suffice for cooling an 800W spindle? Would it even be suitable? Would it need a cooling rad to be used in conjunction with it? (I should perhaps mention that the machine isn't on the go for hours - probably maximum session is about 40 minutes...and even then the spindle isn't be overly taxed...probably running at 10,000RPM milling a PCB or cutting a bit of acrylic.
Many thanks,
Hank.
03-09-2013 #2
I been having a bit of a read of the Chinese spindle thread and from what is being said there the cooling requirements aren't that hard to meet.
I'm currently thinking of mounting a radiator on the back of my gantry with a small pump on top thus limiting the pipe run and total water volume. I was thinking I'd probably use a modified computer cooling system. As Jonathan mentions in this post the dissipated heat is probably of the order of 110W max. Cooling systems for CPUs have to be able to deal with 80W and probably quite a bit more because people using water cooling are often over clocking. If you are willing to run with a reasonable delta temperature (between ambient and radiator) passive cooling should be quite easy. If you want a smaller delta then a 12V computer fan run at 7V would provide good air flow over a radiator and be essentially silent.
03-09-2013 #3
If the system is closed loop, then without a reasonably large tank you will certainly need a radiator of some sort. The easiest option is just to use the parts people use for computer water cooling systems, but the parts for that market tend to be overpriced so unless you can get lucky on eBay I'd substitute them for cheaper options, e.g. the pump you found and a car radiator with a fan for the heat exchanger. I don't think you'll get away without a fan unless you have an unreasonably large heatsink.
It's been done before:
Spindle Water Cooling System Test Start - YouTube
That system looks nice and light.Last edited by Jonathan; 03-09-2013 at 11:00 AM.
03-09-2013 #4
The pump in that youtube video looks like the same item I linked to in my first post (which is quite cheap) ...
DC12V SC-300 Silent 23DB Water Cooling Circulation Pump For Spindle Motor Router | eBay
just where to buy the radiator with integral fan, I found a radiator that seems well priced (so might just lob a quiet fan onto it)....
Aluminum Water Cooling Block Water cooled Row Heat exchanger For PC Computer 90 | eBay
I'm ideally seeking a solution that can be mouted on the rear of the gantry of a 3020 machine (fixed gantry type)
03-09-2013 #5
I wouldn't worry about getting an integral fan with the radiator. Fans are cheap and you'll probably want a half way decent "ultra quiet" one (something like this).
03-09-2013 #6
No need for radiator. Just a waste of money. 1000l/ph pump + 5l car radiator fluid+ big transparent 5l jar from any chinese shop + transparent plastic hoses. Again, anything else is a waste of money. Thats for 0.8kw spindle. 15l have to be ok for the 2.2kw one.
-Water cools also in the plastic tubing on its way
-The tubing should be transparent so you can see eventual bubles
-the car liquid takes away heat better/glycol/ and will not spoil with time/at least for an year, later-yes/
-the car cooling liquid has a color so you can spot leaks
-the jar should be transparent so at all times you see the flow
Never had any problems with this setup doing more than 8h continuous machining.
This is the correct pump 75W Water Pump spindle motor water-cooled circle pump For Engraving machine CNC | eBay
I bought the same locally for 20euro but this one is better because of the brass fitting.
Hope it helps.Last edited by Boyan Silyavski; 03-09-2013 at 03:01 PM.
Do you need to water cool erhm a water cooled spindle?!!
By HankMcSpank in forum Generic Chinese SpindlesReplies: 18Last Post: 02-10-2013, 09:59 PM -
Chinese 2.2 water cooled spindle / Which VFD ?
By dudz in forum Motor Drivers & ControllersReplies: 20Last Post: 16-08-2013, 02:22 PM -
By alex wight in forum Generic Chinese SpindlesReplies: 1Last Post: 21-09-2012, 09:57 PM -
water cooling options for spindle
By routercnc in forum Tool & Tooling TechnologyReplies: 24Last Post: 12-02-2012, 11:22 PM -
(Video) Water spindle cooling system
By jafc76 in forum General DiscussionReplies: 0Last Post: 30-12-2011, 02:31 PM
