03-09-2013 #7
In most circumstances, that's true, but if you're trying to get away without a tank a radiator is certainly needed. For my 2.2kW spindle I have a tank which is filled with about 8L and it's not really enough for more than a few hours. Clearly it depends on how much power you're drawing from the spindle, but 5L of fluid will only be able to absorb the heat for a very short amount of time if the spindle is used at anywhere near rated power. You must be using only a fraction of the rating to get away with 5L.
In Hank's case it's a small spindle on a small machine, so it might be acceptable.
There are plenty of cheaper pumps on eBay...Last edited by Jonathan; 03-09-2013 at 02:53 PM.
Do you need to water cool erhm a water cooled spindle?!!
By HankMcSpank in forum Generic Chinese SpindlesReplies: 18Last Post: 02-10-2013, 09:59 PM -
Chinese 2.2 water cooled spindle / Which VFD ?
By dudz in forum Motor Drivers & ControllersReplies: 20Last Post: 16-08-2013, 02:22 PM -
By alex wight in forum Generic Chinese SpindlesReplies: 1Last Post: 21-09-2012, 09:57 PM -
water cooling options for spindle
By routercnc in forum Tool & Tooling TechnologyReplies: 24Last Post: 12-02-2012, 11:22 PM -
(Video) Water spindle cooling system
By jafc76 in forum General DiscussionReplies: 0Last Post: 30-12-2011, 02:31 PM
