Curious if anyone knows what's the standard fit one goes for on a shaft section where a taperlock bush is going to be mounted? Is it h5 / h6 or something different? shaft dia / taperlock ID is 25mm, here's the tolerances for h5 / h6:
h5: max 25.000mm , min 24.991mm
h6: max 25.000mm , min 24.987mm
Regards,
dsc.
03-09-2013 #2
Doesn't matter, average taperlock will grip a given size plus or minus a post code.
That's one of the saving graces about them, they will fit to damaged shafts.John S -
The Following User Says Thank You to John S For This Useful Post:
03-09-2013 #3
Thanks John. Any specifics on what the max error can be? +/-0.5mm or less? not sure what to ask for on the drawings.
Regards,
T.
03-09-2013 #4
Can't give any specific numbers but I DO know that a 1" (25.4mm) taperlock bush will fit comfortably on a 25mm shaft and still have remaining adjustment. Best practice is obviously to use the closest fitting you can, even if that means selecting an imperial bored bush.
Taperlock and translock bushes
By davethefixer in forum Linear & Rotary MotionReplies: 2Last Post: 22-03-2013, 12:12 PM -
6mm shaft to 6.35mm hole?
By JuKu in forum Metalwork DiscussionReplies: 3Last Post: 15-12-2012, 02:29 PM -
Stepper shaft couplings - can you ID these?
By HankMcSpank in forum Stepper & Servo MotorsReplies: 17Last Post: 15-04-2012, 03:46 PM -
Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
By LoveLearn in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 08-02-2012, 01:52 AM -
Need to drill a spanner shaft
By GeorgeD in forum Metalwork DiscussionReplies: 4Last Post: 31-07-2010, 10:38 PM
