    I am looking at the pics but still not seeing quite how the quill gets moved... and still moves the motor when you turn the quill handle...
    The frictional losses on a ball screw are low. The screw can turn the nut if you have the means to push hard enough.
    Spin the motor by pulling on the handle and you can feel if something is binding. Should be smooth
  2. Quote Originally Posted by Robin Hewitt View Post
    Ah, what is the lead on the screw... I hadn't realised it was that big a lead. But what stops the quill dropping under its own weight then when the motor is powered off? Or is there sufficient stickiness in the cogging to stop that?
    It's 5mm lead, the 32:40 pulley reduction gives 4mm/motor rev
    The quill return spring is there but it wouldn't drop under it's own weight anyway. You gottta pull to spin it.
    Tentatively wired the hybrid Z axis motor up today, a bit of light relief after doing the VAT return.
    Only had 2 Amps spare for it to play with but it doesn't seem to mind one jot, even though it is moving the quill at twice my normal speed
    Also rough cut the honking plate on a bandsaw, see pic, don't know if I'll get anything done tomorrow.
    Robin
    Milled out the honking plate, still needs a slit and a couple of holes opening out but nearly there.
    Not sure I actually need it, I sank the detail 20mm in and it cut it 20.04mm with the bodged plate.Wish I'd tried harder setting the Z in retrospect
    Pic shows honking plate next to the Warco depth stop plate it replaces
    Robin
  1. Haighton Major
    By BillTodd in forum Milling Machines, Builds & Conversions
    Last Post: 14-05-2022, 02:17 PM
  2. WANTED: Conect Minor or Major CNC Milling Machine Wanted
    By stevy123 in forum Items Wanted
    Last Post: 24-08-2011, 10:35 AM
  3. CONVERSION: Buget Warco Major 5 axis conversion
    By Tweaky in forum Conversion Build Logs
    Last Post: 07-10-2010, 04:26 PM
  4. Warco Super Major Mill 3 month old
    By grimreaper in forum Milling Machines, Builds & Conversions
    Last Post: 18-07-2010, 02:50 PM
  5. NEW MEMBER: Warco super major mill
    By ste64 in forum New Member Introductions
    Last Post: 26-05-2010, 04:27 PM
