Thread: Warco Major CNC build log
26-06-2009 #31
26-06-2009 #32It's trig whether you use pythag or not ;)It could be pythagsrus not trig....
BTW Was Michael Jackson's last hit called 'the floor'?
26-06-2009 #33
26-06-2009 #34
Strangely true, when I looked in the box I found an empty 44t packet and a brand spaking new 40t. Nice to have a spare I suppose
I don't think it can twist without bending the screw, I didn't stint on the metal :nope:
I now have the 40t pulley and belt in place with a faux honking plate fudged out of a bit of 2" x 3/4" iron.
It feels good, any shift on the motor moves the handle, moving the handle spins the motor. I would have wired it up but when I looked for a bit of chocolate block connector all I could find was 80A
Time for some G-code to make the real honking plate
Robin
26-06-2009 #35
26-06-2009 #36
26-06-2009 #37
It's actually British Standard Honking Plate.
John S -
27-06-2009 #38
27-06-2009 #39
27-06-2009 #40
It's 5mm lead, the 32:40 pulley reduction gives 4mm/motor rev
The quill return spring is there but it wouldn't drop under it's own weight anyway. You gottta pull to spin it.
Haighton Major
By BillTodd in forum Milling Machines, Builds & ConversionsReplies: 25Last Post: 14-05-2022, 02:17 PM -
WANTED: Conect Minor or Major CNC Milling Machine Wanted
By stevy123 in forum Items WantedReplies: 0Last Post: 24-08-2011, 10:35 AM -
CONVERSION: Buget Warco Major 5 axis conversion
By Tweaky in forum Conversion Build LogsReplies: 45Last Post: 07-10-2010, 04:26 PM -
Warco Super Major Mill 3 month old
By grimreaper in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 18-07-2010, 02:50 PM -
NEW MEMBER: Warco super major mill
By ste64 in forum New Member IntroductionsReplies: 5Last Post: 26-05-2010, 04:27 PM
