Thread: Warco Major CNC build log
	23-06-2009 #11
I'm doing it the same way I did last time, the screw housing bolts to the honking plate. Only difference is I'm using 2 screws this time instead of one. I think it needs a bit extra to lock the screw parallel to the quill.
Not exactly pretty but you can have the X and Y screws if it helps They are cluttering up the workshop, probably going in the bin next time I tidy the shelves. If I find a box I could send the whole she-bang standard parcels.
I bought zero
 backlash nuts from Marchant Dice for the X and Y, odd things that you had to crush sideways to set. I never got the backlash below 3 thou. Also I didn't get the ends machined, just glued on extension sleeves with Loctite. With the benefit of hindsight, a false economy.
The Z axis was a disappointment, nice screw off ebay but I didn't eliminate flex and it always fell slightly short of the mark. I'm hoping the honking plate will fix that.
Robin
Haighton Major
By BillTodd in forum Milling Machines, Builds & ConversionsReplies: 25Last Post: 14-05-2022, 02:17 PM -
WANTED: Conect Minor or Major CNC Milling Machine Wanted
By stevy123 in forum Items WantedReplies: 0Last Post: 24-08-2011, 10:35 AM -
CONVERSION: Buget Warco Major 5 axis conversion
By Tweaky in forum Conversion Build LogsReplies: 45Last Post: 07-10-2010, 04:26 PM -
Warco Super Major Mill 3 month old
By grimreaper in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 18-07-2010, 02:50 PM -
NEW MEMBER: Warco super major mill
By ste64 in forum New Member IntroductionsReplies: 5Last Post: 26-05-2010, 04:27 PM
