  1. #28
    I cut some metal and it came out a bit naff, see before and after pic, arrow points to the problem bit.
    Two changes, I wrote my own dxf to G-code software taking control of the tool path. Bubba, over on CNC zone, told me the Warco column pinch bolts were naff.
    I've been measuring the new part and dimensionally it is slightly undersize, somewhere between -0.00 and -0.05mm
    Theoretically with a bit of compensation I could get the tolerance down to .025 mm if I always used this tool and this collet :dance:
    Bubba suggested I changed the bolts. I looked at them and found they had worn badly. When I thought I was doing them up tight I was actually trying to swage a new thread. I fitted overlength M16's with spacers and anti-seize compound. I can now use a ring spanner rather than the awkward Warco offering and it seems to like it.
ID:	2660   Click image for larger version.
  1. Haighton Major
    By BillTodd in forum Milling Machines, Builds & Conversions
    Last Post: 14-05-2022, 02:17 PM
  2. WANTED: Conect Minor or Major CNC Milling Machine Wanted
    By stevy123 in forum Items Wanted
    Last Post: 24-08-2011, 10:35 AM
  3. CONVERSION: Buget Warco Major 5 axis conversion
    By Tweaky in forum Conversion Build Logs
    Last Post: 07-10-2010, 04:26 PM
  4. Warco Super Major Mill 3 month old
    By grimreaper in forum Milling Machines, Builds & Conversions
    Last Post: 18-07-2010, 02:50 PM
  5. NEW MEMBER: Warco super major mill
    By ste64 in forum New Member Introductions
    Last Post: 26-05-2010, 04:27 PM
