    Curious.
    I wound up the feed rate on that hybrid stepper and it would do 18mm/s but clacked out at 20 mm/s
    I disconnected the Y axis to get some spare Amps then switched the hybrid peak current from 1.9A to 4.2A peak.
    Wouldn't do 18 mm/s anymore :nope:
    Possibilities...
    The cable on the Z is altogether too long and it's having problems controlling the current.
    The stepper driver can't actually cope when you increase the current.
    I imagined it :heehee:
    So, any ideas what driver/PSU combination I need to shop for?
    However, 18mm/s is a lot better than I had before so I made new plates to fit them on the X and Y. Stuck a fanciful strain relief bracket on the X so I can bolt the flexy trunking to it.
  1. Haighton Major
    By BillTodd in forum Milling Machines, Builds & Conversions
    Last Post: 14-05-2022, 02:17 PM
  2. WANTED: Conect Minor or Major CNC Milling Machine Wanted
    By stevy123 in forum Items Wanted
    Last Post: 24-08-2011, 10:35 AM
  3. CONVERSION: Buget Warco Major 5 axis conversion
    By Tweaky in forum Conversion Build Logs
    Last Post: 07-10-2010, 04:26 PM
  4. Warco Super Major Mill 3 month old
    By grimreaper in forum Milling Machines, Builds & Conversions
    Last Post: 18-07-2010, 02:50 PM
  5. NEW MEMBER: Warco super major mill
    By ste64 in forum New Member Introductions
    Last Post: 26-05-2010, 04:27 PM
