Thread: Warco Major CNC build log
23-09-2009 #20
I measured it two ways to compensate for the lumpy bed, but seem to have cocked up :nope:
I reckon my -4 mils East measurement was actually a +4 mils, giving a +-6 mil East West tilt. I mean the tilt has to show even either side, doesn't it? :whistling:
6 mils over a 9cm radius translates to nigh on 0.3mm of packing at the column base, it's around 0.1 degrees out. I could see it was a bit bent when facing with larger endmills but didn't think it was that far out.
New plan. I have some 0.47mm brass sheet, I'll put a strip of that down the West side of the column base then shim the East side until it comes true(ish).
Not much of a plan, but hey, it's a plan. Now where did I put my piercing saw? :naughty:
Haighton Major
By BillTodd in forum Milling Machines, Builds & ConversionsReplies: 25Last Post: 14-05-2022, 02:17 PM -
WANTED: Conect Minor or Major CNC Milling Machine Wanted
By stevy123 in forum Items WantedReplies: 0Last Post: 24-08-2011, 10:35 AM -
CONVERSION: Buget Warco Major 5 axis conversion
By Tweaky in forum Conversion Build LogsReplies: 45Last Post: 07-10-2010, 04:26 PM -
Warco Super Major Mill 3 month old
By grimreaper in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 18-07-2010, 02:50 PM -
NEW MEMBER: Warco super major mill
By ste64 in forum New Member IntroductionsReplies: 5Last Post: 26-05-2010, 04:27 PM
