Thread: new build opinions required
07-01-2014 #11
Thanks for the info. Though here is what i think of it in my case, may be concerning this build also:
-if the machine is rigid like mine and like this will be , may be it shouldn't be a problem. With Hiwin 20 HA bearing spacement at the gantry sides of 40cm/ or even 30/ i don't see how it would go out of true, its not a flimsy machine we are talking about here.
-i would use servos, they will simply stop due to error
I still don't like that design of yours, but that shouldn't discourage you :-)
I don't know if i am understanding you wrong. But:
RP is far more wear prone than ball screw. Ball screw is far more better and smooth. for 6m long table, yes RP, but for anything under 3m-ballscrew.
IMHO the weakest points in order of a DIY machine FYI:
1. Router bit - deflection
2. Z overhang-plate twist
3. Gantry twist and bend ,
4. Gantry sides
5. bearings/assuming you use square
6.Spindle power
7. Balscrew support bearings, spindle bearings
8...etc
You can not bend with steppers a properly constructed machine. They will simply stall. Remember this. Nor you can wear Hiwin bearings if properly mounted. When you have them in your hands you will see why. They will be probably that last element in a machine to fail.
Back to the BOBs
I have another questions in mind concerning the BOBs. Please some one more knowledgeable clear it for me:
-With steppers: If Mach 3 outputs as max 100kHz pulse/ even less normally/, then a normal reliable board that supports 100khz should be ok, yes?
-With servos: If Mach 3 outputs as max 100kHz pulse/ even less normally/, then why should i care to buy a board like the CSMIO or other? I know, apart from the reliability and connections, i mean. Every modern servo drive can upscale by gearing the frequency and generate the proper signal , so why waste money on expensive cards that will do exactly the same thing in fact? I start to believe that the driver generating the pulses will be quite better and reliable..
It seems that mach3 is the limiting factor, not the board?
Design Help Pt2 Required for CNC design/Build
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 38Last Post: 21-07-2014, 02:05 PM -
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 21-10-2011, 04:50 PM -
Opinions
By p1lts in forum General DiscussionReplies: 8Last Post: 03-02-2011, 08:47 PM -
RFQ: Manual Lathe Repair & Syil SX3 CNC Re-build Required.
By Chas in forum Projects, Jobs & RequestsReplies: 0Last Post: 07-11-2010, 09:28 AM
