Thread: new build opinions required
16-12-2013 #11
i haven't order it yet, and i can change if needed, i want to build a multi purpose machine, and i will build a second, task purpose machine, when i have done the first, all in all, i have between 5k - 8k but can up that if i think its worth it.
I will have a number of spindles/heads, and am looking at 600 to 2000rpm options at the mo, i want XYZ basic, solid and strong enough for any material up to approx 200mm, with the top bed having 2 cross bars, splitting it into 3 lower areas with up to an extra 150mm depth, the lowwer areas holding setups for plastics, B/C head, 4th axis, plasma/arc, rotational table .
And i also want nearly a full length of x 4th axis, indexable for carving foam.
I know i will make many mistakes making this macheen, but stripping back and rebuilding replacing, is not a problem, trying out different electronics, is not a problem ( as long as am not waist-full ) . I quite good at pulling projects together, free time permitting.
Design Help Pt2 Required for CNC design/Build
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 38Last Post: 21-07-2014, 02:05 PM -
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 21-10-2011, 04:50 PM -
Opinions
By p1lts in forum General DiscussionReplies: 8Last Post: 03-02-2011, 08:47 PM -
RFQ: Manual Lathe Repair & Syil SX3 CNC Re-build Required.
By Chas in forum Projects, Jobs & RequestsReplies: 0Last Post: 07-11-2010, 09:28 AM
