Thread: new build opinions required
19-12-2013 #11
Hi
i started with the plan that the z should be able to handle different spindles+additions, without differing what forces it can handle in both +-xy. most of the moving gantry designs, like the one you linked to, favour one direction down X, and rely on weight of the garntry to offset the stability looses you get by having to mount the spindle forword of the Y, on the drawing you link to, every mm forword the z mech is away from Y, the force you can apply at the bit tip drops substantialy, and would be different X+ than X-.
so, the problem/limit for z, when considering deflections , is all in the Y, when you factor in a 4th axis, again the differing forces between X+ and X-, start loosing accuracy , the longer the jobs running, the worse it gets, the bigger the job is down the x axis, the faster this will happen. .
but, if you have 2 of them Y axis you linked to, facing each other, and the Z in the center, Zs force is equal on X+- and Y+-. the forces Y can take, could be ajusted by spacing th 2 bearings per rail further apart
then, Z drop, is the next place you start looking at, will try and get it in sckechup tomorrow, failing that, i will take a photo of my drawings and post that
Design Help Pt2 Required for CNC design/Build
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 38Last Post: 21-07-2014, 02:05 PM -
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 21-10-2011, 04:50 PM -
Opinions
By p1lts in forum General DiscussionReplies: 8Last Post: 03-02-2011, 08:47 PM -
RFQ: Manual Lathe Repair & Syil SX3 CNC Re-build Required.
By Chas in forum Projects, Jobs & RequestsReplies: 0Last Post: 07-11-2010, 09:28 AM
