Thread: new build opinions required
Hi
am trying to nail down the interface card i will use, has anyone used any of the following, ( listed in preference )
6 axis 250KHz USB CNC card, MACH3 plugin, auto zero, auto tool setting, API | eBay
Martzis USB HID Interface (MUHI) Card Board For Linux EMC and Mach 3 PC Via BUS | eBay
5Axis Upgraded CNC Breakout Board Interface Set +Keypad +Display, Manual Control | eBay
03-01-2014 #2
Hi George,
i don't know from where you dig out that boards, as i am also at this point but see them for first time.
The first one has its outputs 3v, so you have to check out if compatible with the drivers you intend to use
The second one seems I/0 board only, unable to generate train pulse for motors if i am not mistaken
The third one...no, seems some problematic chinese board
It seems money is an issue, then take a look at :
-http://www.planet-cnc.com usb boards with proprietary software instead Mach3, if you still don't own it
-if you want to go Linux, look at the Mesa FPGA boards, search the Linux forum
-CNCdrive - motion controls
Of course depends how many axis you will like to drive,
Then comes the Ethernet smooth stepper + BOB / PMDX126/ or a CSMIO 4 axis board/ or the expensive 6 axis, which in fact has all that one should look for in a board altogether/
Another possible solution i am looking at now is the KFLOP, which for the moment seems to be my choice, money wise for what it offers
Pokeys is also a good money wise .
Design Help Pt2 Required for CNC design/Build
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 38Last Post: 21-07-2014, 02:05 PM -
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 21-10-2011, 04:50 PM -
Opinions
By p1lts in forum General DiscussionReplies: 8Last Post: 03-02-2011, 08:47 PM -
RFQ: Manual Lathe Repair & Syil SX3 CNC Re-build Required.
By Chas in forum Projects, Jobs & RequestsReplies: 0Last Post: 07-11-2010, 09:28 AM
