Thread: new build opinions required
05-01-2014 #11
It's a very nice bit of kit but be careful because I think the developer has thrown the teddy out the pram with Artsoft because he doesn't like the direction they are taking with Mach4.?
Regards the Kflop and Galia etc then unless your intending on using Servo's with high count encoders then your wasting your money has other than quality they offer no more advantage than the ESS or other Sub £200 cards for steppers.
If your using steppers and don't need slaved Axis then the Csmio-IP-M is by far the best I've ever used and use's industry standard 24V differential signals. there's No Bob's needed and very high quality units in a neat package.
If I needed higher pulse rates for servo's then I wouldn't hesitate to buy the higher priced Csmio-Ip-S which will give many of the other much more expensive high end motion controllers a good run for there money.
The Kflop is a nice bit of kit but it's still using USB and Ethernet is so much better and noise immune compared to USB. I've never been a fan of USB for Bob's etc and while I didn't have too much trouble with using the USB version of the SS I did get some troubles. With Ethernet I've not had any issues with noise at all other than a Dodgy card and can run machine from in the house with a laptop sat on my knee if I like using the network.!! . . . . I don't but I could.!!
Design Help Pt2 Required for CNC design/Build
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 38Last Post: 21-07-2014, 02:05 PM -
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 21-10-2011, 04:50 PM -
Opinions
By p1lts in forum General DiscussionReplies: 8Last Post: 03-02-2011, 08:47 PM -
RFQ: Manual Lathe Repair & Syil SX3 CNC Re-build Required.
By Chas in forum Projects, Jobs & RequestsReplies: 0Last Post: 07-11-2010, 09:28 AM
