    I am trying to drill 500 off 2.395mm dia holes in an ali casting but the drill I am using keeps building up with swarf on the drill flutes after just one hole has been drilled.
    I am using a special sphinx drill for this job but would like some help with why the drill is building up with swarf.
    I am using a horizontal milling machine to do this job and I have tried the following speeds and feeds
    S10000 F600
    S10000 F400
    S6000 F300
    I am using G83 peck cycle with pecks on 3.5mm and the hole is 10mm thru.
    I have also tried using thru spindle coolant and still no luck.
    Any help would be appreciated.
    Have you tried blowing air at it with a decent pressure while drilling ?
    Have you tried wd40? Apparently it's the bees knees for cutting aluminum.
    Lives in East Lothian, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    Is the feedrate within spec for the particular drill you're using?
    So far you've tried-
    0.06mm/rev
    0.04mm/rev
    0.05mm/rev
    Looking at a basic polished cobalt drill (you are using polished drills?), the recommended feedrate should be about 0.1mm/rev, while a solid carbide is slightly higher depending on the alloy, and high-helix drills being higher yet at around 0.15mm/rev.
    Hi Woolley
    You really need a suitable coolant,and that would be parrafin.
  1. Hole Radius
    By benkat in forum Machine Discussion
    Last Post: 03-03-2014, 05:29 PM
  2. Epoxy granite or mineral casting
    By mike mcdermid in forum Gantry/Router Machines & Building
    Last Post: 20-02-2014, 06:21 PM
  3. Replies: 3
    Last Post: 16-08-2012, 08:50 AM
  4. Casting foundry around the midlands!
    By AdCNC in forum General Discussion
    Last Post: 17-05-2011, 12:04 AM
  5. help needed drilling bore hole in mxl timing pulley
    By geekinesis in forum Gantry/Router Machines & Building
    Last Post: 02-02-2011, 01:07 PM
