04-09-2013 #4
Is the feedrate within spec for the particular drill you're using?
So far you've tried-
0.06mm/rev
0.04mm/rev
0.05mm/rev
Looking at a basic polished cobalt drill (you are using polished drills?), the recommended feedrate should be about 0.1mm/rev, while a solid carbide is slightly higher depending on the alloy, and high-helix drills being higher yet at around 0.15mm/rev.
Hole Radius
By benkat in forum Machine DiscussionReplies: 0Last Post: 03-03-2014, 05:29 PM -
Epoxy granite or mineral casting
By mike mcdermid in forum Gantry/Router Machines & BuildingReplies: 46Last Post: 20-02-2014, 06:21 PM -
RFQ: 5 Axis Hole Drilling in Plywood - 1260 holes in 64 boards - help very much needed!
By pjm699 in forum Projects, Jobs & RequestsReplies: 3Last Post: 16-08-2012, 08:50 AM -
Casting foundry around the midlands!
By AdCNC in forum General DiscussionReplies: 2Last Post: 17-05-2011, 12:04 AM -
help needed drilling bore hole in mxl timing pulley
By geekinesis in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 02-02-2011, 01:07 PM
