Whilst rolling you're own is interesting (indeed, a rite of passage around these parts!) & you'll certainly end up with the most suitable machine, it'll likely consume you (as it tends to do with everyone else), I now look at owning a CNC machine as a means to an end (not a 'lifestyle'), so I won't be building anymore machines! (frankly, my engineering skills suck too!)
If I knew what I know now before I decided on what to do (for milling pcbs) ...I'd look out for something like a simple/small a sable 2015 secondhand (or import one new Sable-2015 CNC ROUTER / ENGRAVER-mill,PCB's,engraving(complete kits) | eBay ), but then upgrade the driving gear to ballscrews (as opposed to the bog standard M10 rod it comes with) ...the sable is actually incredibly well made.
I've got a 2015 machine ..I was going to upgrade it with ballscrews but then a proper grown up used 3020 fixed gantry (moving table) appeared on the scene & I snagged it....
http://img.alibaba.com/photo/7350997...ry_RS_3020.jpg
...but frankly, now that it's here with me, it seems way overkill to mill 1.6mm pcbs!
Alas, when it comes to pre-made machines, ballscrews don't seem to appear as standard until you get up to 3020 size machines (& even then, just the higher end ones)
Oh yeah.... you might want to consider ponying up for CNC-USB software (vs Mach3) as it has auto-levelling built in - and when it comes to milling pcb, a level copper clad board is what you want, what you really really want.
re using a CNC machine for pick n' place ...of course it can be done & on the face of it, it seems a fantastic idea...but check out youtube & watch videos of those who have turned their CNC machine into a pick & place machines.... talk about slow...... it's akin to owning a truck & expecting it to be as nimble & adept as a stunt motorcycle.Last edited by HankMcSpank; 04-09-2013 at 05:36 PM.
The Following User Says Thank You to HankMcSpank For This Useful Post:
06-09-2013 #2
Totally agree – I think the idea of owning a CNC machine is very sexy and I look forward to that day – but – IT IS A TOOL for achieving a higher output and increased accuracy, too easy to get sidelined by the tech when there is work to be done and money to be made.
Milling PCB's was not even a consideration – but it does offer an attractive alternative to photo/toner circuit printing – as for the CNC-USB software that sounds very useful and although I have heard of the Mach3 s/w don't know much about it's capabilities. PS cheers for alerting me to the Sable - hadn't come across that one before.If I knew what I know now before I decided on what to do (for milling pcbs) ...I'd look out for something like a simple/small a sable 2015 secondhand (or import one new Sable-2015 CNC ROUTER / ENGRAVER-mill,PCB's,engraving(complete kits) | eBay ), but then upgrade the driving gear to ballscrews (as opposed to the bog standard M10 rod it comes with) ...the sable is actually incredibly well made.
Thanks for your comments HankMcSpank - regards Kev
gerber to dxf for PCBs
By Web Goblin in forum Computer SoftwareReplies: 4Last Post: 26-10-2013, 08:25 PM -
Where to get PCBs made in reasonable quantities?
By Jonathan in forum General ElectronicsReplies: 7Last Post: 07-09-2013, 05:25 PM -
desktop CNC to cut alloy
By 8900120d in forum Machine DiscussionReplies: 9Last Post: 26-07-2013, 06:45 PM -
Desktop cnc, HELP
By Walkz69 in forum Machine DiscussionReplies: 1Last Post: 25-05-2013, 11:30 AM -
How hard is it to make diy PCBs if you’re a Noob ?
By Fivetide in forum General ElectronicsReplies: 18Last Post: 05-04-2013, 12:10 PM
