Thread: Milling mild steel
05-09-2013 #11
Milling machine is 167kg, router is 225kg and will be more when filled with sand, so yes. More importantly it's also stiffer than the milling machine in at least one axis and has the same amount of backlash as your milling machine :)
It depends on the situation. I would recommend it to Sasha (whose machine it is), because that's all he's got and can't get a reasonable size milling machine in his house. However if you're cutting a lot of steel then clearly using a lower speed spindle would be the way forward.
I won one of the fancy blue tools on eBay cheaply a while ago but I've not tried it yet as it seems like it would be just too easy to break. In dudz's situation I would try using cheap 1/8" carbide cutters as the small diameter makes the high spindle speed more reasonable (6000rpm should be OK) plus you can break a fair few finding the sweet spot before you've spent as much as the 'X5070' costs.
On a related topic, if you've got one of the Chinese water cooled spindles it's possible to get a bit more torque out of it at low speed. All you have to do is alter the V/f curve parameters in the VFD to raise the voltage slightly at low speed. This increases the flux and thus the torque output available, however you can only gain a little due to saturation. The no-load losses at low speed will increase dramatically (e.g. 10x more) so only raise the voltage a little bit at a time, and keep an eye on the no load current. Clearly this means your water cooling system must be good. You can gain a useful amount of torque from doing this, but do be very careful as it's probably an easy way to burn out the spindle if you're not careful.
RFQ: Several mild steel parts
By dudz in forum Projects, Jobs & RequestsReplies: 6Last Post: 26-08-2013, 11:37 AM -
How do I get this widget made (a small rectangular bit of 1.6mm mild steel)
By HankMcSpank in forum Marketplace DiscussionReplies: 25Last Post: 03-05-2013, 09:31 AM -
Cutting 1.6mm mild steel with a CNC machine?
By HankMcSpank in forum Machine DiscussionReplies: 4Last Post: 01-05-2012, 09:56 PM -
Homemade desktop CNC - cutting 0.8mm mild steel out the question?
By HankMcSpank in forum General DiscussionReplies: 7Last Post: 16-04-2010, 09:37 AM -
Where to get 1/8" sheet mild steel laser/water jet cut?
By HankMcSpank in forum Marketplace DiscussionReplies: 28Last Post: 10-02-2010, 01:28 AM
