Thread: Milling mild steel
16-02-2014 #9
I'll just try and sneak in a quick reply before Jazz arrives (ooer missus smiley)
- blank line inserted here -
You can't slow the spindle so you have to use tiny tooling to get some semblance of the right ft/min, then you work out the feed rate for a credible chip thickness and it is stupidly fast, so you reduce the depth of cut to reduce the horsepower which has to go down the spindly little tool to reach the tip, find the DOC is less than the backlash on your Z axis, realise it is impossible and something has to change. What you really need to do is cut the rpm but that puts you back to square one
RFQ: Several mild steel parts
By dudz in forum Projects, Jobs & RequestsReplies: 6Last Post: 26-08-2013, 11:37 AM -
How do I get this widget made (a small rectangular bit of 1.6mm mild steel)
By HankMcSpank in forum Marketplace DiscussionReplies: 25Last Post: 03-05-2013, 09:31 AM -
Cutting 1.6mm mild steel with a CNC machine?
By HankMcSpank in forum Machine DiscussionReplies: 4Last Post: 01-05-2012, 09:56 PM -
Homemade desktop CNC - cutting 0.8mm mild steel out the question?
By HankMcSpank in forum General DiscussionReplies: 7Last Post: 16-04-2010, 09:37 AM -
Where to get 1/8" sheet mild steel laser/water jet cut?
By HankMcSpank in forum Marketplace DiscussionReplies: 28Last Post: 10-02-2010, 01:28 AM
