Hello, I'm relatively new to CNC myself but I've been looking at these people which you might not have come across.
cnc router | eBay
Mantech Machinery - CNC Routers
Prototools Prototype in House - Home
Products
Maxicam - Compact Series CNC Router
Welcome To EXEL CNC AUTOMATION
CNC Router Machine | Computer Numerical Control Retrofit Systems
I can't recommend any myself but it may be some help to you. In any event I'm sure you will get replies from others in the forum.
Edit: (Due to previous brain situation courtesy of Murphy's Stout) When I said, "I can't recommend any myself", what I meant was, because I've had no experience with them, not because I knew there was something wrong with them.Last edited by EddyCurrent; 05-09-2013 at 09:07 AM.
04-09-2013 #2
Hello Alan,
I too am a self build noob, with no track record so bear that in mind :-)
I do have quite a bit of experience with CNC in the glass industry though, both operating and programming.
Glass CNC is BIG stuff, you are talking 6 ton+ for grooving (brilliant cutting) and edgework (table tops, balustrades etc)
Stone machines are essentially glass machines with the word glass crossed out and stone written below
You will probably be ok with very light engraving on typical self built CNC machines, but as far as glass/stone goes that's about it.
The sandblasting we do is computer cut masking material stuck on glass and then Sandblasted in a cabinet. Other than cutting the mask i doubt CNC will help.
Wooden signs is absolutely bang in the zone for self built/low end commercial CNC routers.
They can produce some outstanding designs.
Many self built routers far exceed the quality of low end commercial ones. Of course some don't. lol (Prob mine)
As to build or buy. If you have the time then definately build your own.
You need to read and read and eventually it will fall into place.
You will understand the machine FAR more than if you bought it and be able to service and fix it yourself.
The cost both financially and timewise of relying on a service company to maintain and fix a CNC can be VERY high.
Of course if you don't have the time/confidence/inclination to build then you will have to buy.
If so be sure to ask about maintenance & ongoing costs.
Hopefully more experienced folk will be able to give more detailed advice.
GreenyLast edited by Greeny; 04-09-2013 at 09:29 PM. Reason: clarification
04-09-2013 #3
Hi Greeny
Thanks for taking the time to reply.
I have seen the glass equipment and yes, it is major engineering, saw a fantastic machine that did brilliant cutting at a Glassex show, a huge beast and at a very reasonable price of 120,000 Euros lol.
The way you do your sandblasting is identical to mine except i also do deep carving on glass as well. Same principle though and I use a plotter/cutter for the mask (which I suppose is a small CNC).
I would love to build my own but I think time will be against me there, mind you I don't know how long it takes???
Most of the stone carving machines I have seen are pretty much the same format as a wood carving machine but with a recirculating water supply and filter for the coolant spray where needed.
Thanks again
Alan
Alan
04-09-2013 #4
Was it an Intermac? The company I work for has 2 Intermac master grooves (brilliant cutters), an Intermac master edge, and a bottero edge. I don't run them any more, (but can get involved if they break!) They are big beasts, 3000 x 1500, 8kw spindles,auto tool change, the whole enchillada!! Tempremental buggers though! Italian.
The Bottero is a great machine, but you pay for quality.
I know your looking for a smaller machine and I don't mean to be negative, but water cooling and very abrasive swarf/grit take a big toll on the machines, I imagine stone carving will be very similar. Even though granite and marble are slightly softer than glass, the grit gets everywhere and seems to wear everything prematurely. Be very careful any machine you look at will go the distance. If poss ask to visit someone who's had one for a while. Also ask about tooling costs. Diamond tooling is darn expensive.
On the plus side I imagine there's decent money in custom stone carving though
Good luck.
07-09-2013 #5
alboy, I expect you saw this but just in case;
CNC router engraver | eBay
07-09-2013 #6
Hi Eddycurrent
No I hadn't seen that one and i spent ages looking on ebay yesterday lol. It seems a bit light at 20kg but I have come across the type that you can move around and place on top of larger slabs. I have emailed the seller. Will let you know.
Al
08-09-2013 #7
Received email from the seller, unwilling to state the manufacturer, other than saying he bought it from Slovakia. price gone up to £2000 as he says he upgraded the machine by making it wider, now 1000mm wide as opposed to 570 before
why would you go to the expense of making the machine twice as wide while you have it up for auction?
Also like pulling teeth trying to get answers to all my questions.
hmmmmmmmm
08-09-2013 #8
Sounds weird that he's selling something different to his auction price and description.
If you wanted something similar I'm sure it would not take a lot of building (thanks to the info and members on this forum) but they would not let you build it like that
another
http://www.ebay.co.uk/itm/CNC-Router...item27d79aff3cLast edited by EddyCurrent; 08-09-2013 at 12:46 PM.
04-09-2013 #9
Bloody hell Lee's at it again.
By John S in forum General DiscussionReplies: 18Last Post: 19-12-2013, 04:53 PM -
Massive mig welder hell to move
By GeorgeD in forum Welding, Brazing & EquipmentReplies: 25Last Post: 09-08-2010, 10:45 PM
