Thread: meerkat
Ok well first lets check we are both singing from the same hymn sheet.? Because Pin5 on the TB6560AHQ board manual I'm looking at is Z Step. If you have manual post it or give me a link.
What you need to do is identify input pins 10 thru 13 and the ground pin.
In the manual I'm looking at it shows these on a little white 5 pin connector on same side has parallel port and just behind the 15pin manual interface connector.
The pin closest to edge of board is Ground then pin13 is next then 12,11 and 10 is furthest away just jump between 10 and Gnd and the M1,M2,M3,M4,M5,M6home led should light up. (Also has you have it now all the limits will light up has well and probably input #1,2,3.)
If this works then just wire the Home switches in series and connect to pin 10.
Wire limits in series and connect to pin11 but remember to change limit inputs to pin11 don't use the auto set best done manually it's unreliable.
E-stop then goes to pin 13, again set E-stop to pin13 in inputs.
This will leave you with pin12 spare for things like probe etc.Last edited by JAZZCNC; 12-09-2013 at 10:50 PM.
