    Hi.
    I tried making a 4th axis using one of these cheap rotary tables off the bay
    RDGTOOLS 100mm TILTING ROTARY TABLE & 100MM 3-JAW CHUCK | eBay
    problem is, even if you exclude the stepper motor coupling, remove that altogether... one hand holding the input shaft, and the other on the chuck, you notice atleast 1mm of 'backlash' play.... unless you 'lock' it... which of course when used the way its intended (as a rotary table) is fine... but as a 4th axis its not.
    so.... need a new plan... I need an accurate way of controlling a 100mm chuck from a stepper motor with minimal backlash
    can anybody make any recommendations?
    ive noticed this
    CNC 4th Axis Rotary Table (100mm / 4 inch) with Flying Leads | eBay
    the description says
    Maximum backlash (all rotary tables are tested to be within this spec): 20 arc minutes
    Typical backlash (most rotary tables are shipped within this spec): 15 arc minutes
    but im not as clever as most on here... can anybody advise if 20 arc minutes equates to around 2mm of backlash? on a 50mm diameter? so...???
    any advice etc would be very much appreciated, so thanks in advance
  2. 1 degree on a 100mm dia chuck is 100*3.142/360=0.87mm
    20arcmnutes us .334 degrees so about 0.3mm
    It sounds like you've not got the worm gear engaged properly. There worm gear is on an eccentric, so you can rotate the motor mount etc to push the gear into a tighter mesh, which will substantially reduce the backlash. There's a screw you undo, then the motor will rotate freely... it probably says in the instructions.
    The rotary table you linked to wont be any better than the one you've got if it's adjusted properly.
    P.S. You might want to put a grommet round the motor cables so that the aluminium plate doesn't cut them.
    Hi M8
    Check to see if your eccentric is at it's maximum travel, if it still has some throw left you could strip the unit down and try lapping the pinion and wheel with solvol autosol or similar, and then if needed make a new eccentric with slightly more throw (if you have to remove a lot of material for a snug fit between pinion and wheel)
  1. WANTED: 4" / 100mm lathe chuck
    By Jonathan in forum Items Wanted
    Last Post: 23-04-2012, 03:05 PM
  2. Which chuck to fit 6" rotary table??
    By wiatroda in forum General Discussion
    Last Post: 10-08-2011, 08:47 AM
  3. Mounting a chuck on a Rotary table
    Last Post: 02-09-2010, 07:23 PM
  4. Rotary Table CNCing
    By irving2008 in forum Gantry/Router Machines & Building
    Last Post: 19-02-2010, 11:57 PM
  5. Setting up work on the rotary table
    Last Post: 09-01-2010, 10:27 AM
