10-11-2013 #13
I've recently ordered a PDMX-126 and a Smoothstepper ESS to use with my machine which will be running twin screws with slaved steppers on the long axis (1200mm long). I've just been reading that there is an issue with the SS regarding homing slaved motors using two switches (one per motor) : Ethernet Smooth Stepper, What Are The Negatives, What Features Are Missing?
Does anyone have experience of this? Is there a workaround apart from only using one switch?
Cheers,
Si.
USB TO Parallel Port DIY Interface
By Lee Roberts in forum Electronic Project BuildingReplies: 42Last Post: 17-02-2018, 07:46 PM -
What is the function of a parallel port breakout board?
By hbx in forum Machine Control SoftwareReplies: 13Last Post: 12-03-2013, 06:18 PM -
parallel port address
By Dan Brown in forum Artsoft Mach (3 & 4)Replies: 6Last Post: 07-01-2010, 12:04 PM -
Laptop, ie no parallel port?
By tompsky in forum Laptops & TabletsReplies: 3Last Post: 11-11-2008, 07:12 PM -
Which USB parallel port emulator is the best
By bruce_miranda in forum General ElectronicsReplies: 1Last Post: 18-09-2008, 03:38 PM
