    Thanks Jonathan...quite a difference - even with the 3kw spindle lying on a large flat table (which will possibly 'amplify' the spindle's sound/vibrations ....just like a soundbox on an acoustic guitar).
    The smaller spindle sounds quite loud to my ears...but again, that might be a trick of the camera mic.
    (btw your audio in that youtube video drops out completely at approx 4m16s)
    Quote Originally Posted by HankMcSpank View Post
    Hmm, that's annoying as I just deleted the original so it'll have to stay like that. In the rest of the video I put the radio on again to demonstrate how you can't hear it with the old spindle running and also commented that it's all a bit insignificant compared to the noise generated when cutting unless perhaps what you're cutting uses very small/light cuts.
    No worries you went above & beyond the call of duty - pont taken about the noise of the actual cutting itself, but for me it's mainly gonna be just 0.1mm deep into FR4! (so the noise of the spindle is likely to be the main contributing factor wrt strained man/wife relationships!)
    So, something arrived in the post today, from Italy ...
    ...yay!
    About £120 delivered (thanks for the heads up silyavski).
    Sure, I can buy cheaper if I go the Chinese path, but I've had some horrific experiences with chinese electronics over the past couple of years (TB6560 anyone?), so I decided to pony up the extra forty quid which will hopefully save me some grief!
    Great so is it running yet.? . . . . If not why not. . . . . .Think you'll like it.!!
    A bit more heads up:
    The Speed and corresponding frequencies in HZ, measured carefully with a device, you r can be slightly different but not so much. Open it in new window to see it better and enlarge it with "control" + "+" , or PM if you can not read it:
Name:	VDF speeds.jpg
    The typical connection / check well the manual/
    cables from left to right
    - trip ,
    - PWM control,
    - ??? i forgot , not so sure, but it was enable to the BOB, in case of power loss it stops everything/
  7. The Following User Says Thank You to Boyan Silyavski For This Useful Post:
  8. #7
    Looks like section 6.18.3 shows how to configure the display to show motor speed.
  9. The Following User Says Thank You to EddyCurrent For This Useful Post:
  1. Mach3 Controlling Huanyang HY02D223B 2.2KW VFD
    By Mad Professor in forum Spindles & Drive Motors
    Last Post: 01-10-2016, 10:21 AM
  2. Workshop & Noise Help
    By kemo_2002 in forum Workshop & Equipment
    Last Post: 12-04-2014, 10:16 PM
  3. controlling a stepper with a simple trigger switch
    By phill05 in forum Stepper & Servo Motors
    Last Post: 06-02-2014, 02:18 PM
  4. Motor noise
    By M250cnc in forum General Electronics
    Last Post: 25-11-2010, 02:06 PM
  5. PDA Controlling A Steeper Motor
    By ceaser in forum Stepper & Servo Motors
    Last Post: 23-05-2009, 03:03 PM
