  1. #4
    As you probably guessed, the reason I spoke in the youtube video you linked to was so that you could set the volume so that I'm speaking at a normal volume, and judge the noise from the spindle accordingly.
    I doubt the spindle from amazon will be quiet as it has a fan on the end, so there will be noise created by the airflow. This is unnecessary when you can quietly water cool it. Don't be afraid of the water cooling - it can be simple and easy.
    If you go for one of the better quality (and much more expensive) water cooled spindles, I'm pretty confident you'll find it's a lot quieter than the standard 2.2kW ones. The one I used here is that type, and I recently obtained a 3kW one on eBay for the right price which is even quieter:
Name:	DSC01830 (Large).JPG
    Admittely it's a bit on the large size for your machine, but I expect the 0.8kW one isn't going to be worse. Also you'll get much lower runout (a few micrometers) with these spindles, which could be an advantage if you're cutting a particularly detailed PCB. I can post a video with them both switched on one at a time if you want to compare?
    Edit: Unfortunately I don't have a new enough phone to measure sound level.
    P.S. Where about is 'on the move'? Clearly the best way is for you to actually listen to one - you're welcome to pop round...
  2. The Following User Says Thank You to Jonathan For This Useful Post:
  1. Mach3 Controlling Huanyang HY02D223B 2.2KW VFD
    By Mad Professor in forum Spindles & Drive Motors
    Last Post: 01-10-2016, 10:21 AM
  2. Workshop & Noise Help
    By kemo_2002 in forum Workshop & Equipment
    Last Post: 12-04-2014, 10:16 PM
  3. controlling a stepper with a simple trigger switch
    By phill05 in forum Stepper & Servo Motors
    Last Post: 06-02-2014, 02:18 PM
  4. Motor noise
    By M250cnc in forum General Electronics
    Last Post: 25-11-2010, 02:06 PM
  5. PDA Controlling A Steeper Motor
    By ceaser in forum Stepper & Servo Motors
    Last Post: 23-05-2009, 03:03 PM
